09-21-2010 #1
- Aug 2004
- 133
Having some brake problems...please help!!!
78 Malibu g body. I did a lsx swap and in the process i did some brake up grades as well. The car has Baer track system with pbr calipers. I had the Front calipers and parts powercoated. I also changed from a brake booster to a factory style grand national hydraboost. I changed all the brake lines from the prop valve forward to braided stainless. The diameters of the lines from the master cylinder down to the prop valve are the same ( stainlees braided from areoquipe). From the prop valve back to the rear is the same...bear discs as well on the rear. I had zero problems before. This is what the car is doing. Car has a awesome pedal when cool. As i drive the car for about 30 min or so with NORMAL stop and go driving the pedal starts to get harder and the car starts to stop on its own. You can smell the brakes. I left the car on a slight incline with it in nuetral, the car didnt move...as it cooled down it started to roll. All the rotors are reading about 340 degrees. I do believe the front calipers are free of trash and have no powder in spots where it does not belong. After 30 min of driving you can tap the brake pedal and the car will stop on a dime. Then its hell getting it to move again. I don't have a clue on whats going on. It's almost like the hydroboost is building to much pressure??? All new lines, new master, a new ( rebuilt ) hydroboost, correct size lines for hydroboost, power streering is great, Thanks for taking the time to read. Im about this close to swaping back to a booster...Any ideas are fantastic.
