    Results 1 to 9 of 9
      Melbourne, FL
      Stupid master cylinder question ...
      Ok have a sort of dumb master cylinder question. I'm using the hydroboost system from a 1978 Eldorado on my 67 'Bird. Now "normally" the rule of thumb is the larger reservoir is for the front and smaller rear. Well this master cylinder has the same size reservoirs. But it does have two different size ports. One is 9/16 x 18 and the other is 1/2 x 20. So safe to assume the larger port is the front brakes and the smaller is teh rear???
      Like I said dumb question but better safe than sorry.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
