      Feb 2007
      Tinley Park, IL
      Difference Between 92/93 & 94 Astro HB
      My Bendix catalog shows the same model number for 92 & 93 Astro van HB unit, but a different number for 94. Anybody know the difference?
      I can get them rebuilt dirt cheap at work, but they frown upon returning a special order. I'd like to know ahead time exactly which I need.
      Nick ~
      1969 Cutlass
      Oregon
      I'm fairly certain that the only difference between those units is in the 4-stud mounting flange/bracket that is included with the 1994-1995 units. The 1990-1993 hydro-boost units didn't include a plate type bracket as far as I know.
      Tobin
      KORE3
      It's what I does.
      Feb 2007
      Tinley Park, IL
      Thanks Tobin. I have your C5/C6 kit on my Cutlass that I installed last year, works great I just don't care for the feel of manual brakes, especially at lower speeds.
      Probably switching to hydroboost this winter. I currently have 7/8 Malibu MC and the 'aggressive' pads you suggested to go with the manual set up. Is there an OE MC you would suggest with the Astro hydroboost? What about a less aggressive pad? I do like the Hawk pads if they have something else.
      Nick ~
      1969 Cutlass
      Feb 2007
      Vancouver, WA
      Not to speak for Tobin, but hydroboost and C5/6 stuff works killer with a 1 1/8 bore MC.
      Oregon
      I'm with Al on this one. The 1-1/8" bore units are plentiful, cheap and usually the best place to start as a result. We'd usually suggest running a somewhat lower CoF pad like the Hawk Ceramic (EE) over the HPS (FF) or HP+ (GG) like you have now. The HP+ pads with hydro can make your brakes feel a lot like a light switch, on or off, although you have them so it wouldn't hurt for you to try them. The stickier your tires are the higher the CoF you can typically tolerate.
      Tobin
      KORE3
      It's what I does.
      May 2009
      Quote Originally Posted by Apogee View Post
      Any leads on OEM applications for 1-1/8 bore master cylinders?
      Preferably aluminum with driver's side ports, but I'll take any info you've got.
      I did find one 1-1/8" bore from vacuum boosted 96-2002 Chev Express/GMC Savanna (1500/2500), not sure how suitable that would be, any other applications you know of, off hand?
      Feb 2007
      Vancouver, WA
      Just about everything that used the single piston front/rear drum in a boosted app used the 1 1/8 bore MC. 69 Camaro with power front discs for example. That MC "should" have a RPV in the rear port which you might want to remove. Something tells me there is a late 60's Corvette MC for power disc/disc that is the same casting but w/o the RPV in the rear port that is 1 1/8 as well.
