    Thread: Tire pressure
      Apr 2003
      Nyköping, Sweden
      Country Flag: Sweden
      Tire pressure
      What amount of tire pressure is recomended on big tire like I have, 275/40x17 and 245/45x17?
      Wide tires can be difficult to pressure correctly, you can easily go wrong and you will not get the whole surface to the ground.
      As it is now my car feels very stiff. OK I have Hotchkis gear on it and Koni shocks set to the medium setting. So I can not expect it to be a cruiser. Tirepressure is anyway a easy tuning parameter and to have it correct is important.
      Jan
      Jan Suhr
      Nyköping, Sweden
      1969 Pro touring Camaro Z/28 LS1/T56
      Scandinavian Pro Touring Forum protouring.se
      I'm not sure how it will work on the street but we optimize tire pressure on a track by getting them up to temp and then taking the temps at the outside, middle and inside of the tread. Add or subtract pressure to even the temps all the way across. Cold middle, add. Hot middle, subtract.
      Wally
      westchester county new york
      you can try try less shock dampening, soften the shocks one click and see how it feels.your only complaint was ride quality so maybe you will like the softer setup better on the street.
