    Results 1 to 18 of 18
      Phoenix, AZ
      Chevelle T56 Install - WTF
      In the midst of my LQ9-T56 install, I have run into a problem: Now that the trans has been bolted up to the engine, and the trans tunnel has been cut out, it is very obvious that the transmission has a rotation to it (5 degrees counterclockwise on a fore-aft axis down the centerline of the car). Since I have never had a T56 in this car before, let alone an M/T, I don't know if this is a problem, or an intentional design (bias the shifter towards the driver??). From the motor side, things look OK, although I am having a hard time locating a good, flat surface to take an angle measurement to confirm.
      To address the obvious, I've had the car for a number of years now, and never experienced this problem before with a TH350 or 4L60E in the car. The LQ9 installed easily, and the motor mounts, stands, and adapter plates (Edelbrock) are all new.
      If anyone has any insight or suggestions, I would greatly appreciate it. Trying to figure out the root cause and not come up with a half-baked solution like shimming the motor mounts.
      ~ Jason
      Wichita, KS
      im not sure which intake manifold you have, but some of them have a 3 bolt style throttle body and some have a 4 bolt. if it is a 4 bolt you could thread 2 bolts into the manifold and rest your gauge on the bolts.
      67 GTO, LS2, T56
      WILWOOD, FORGELINE, RIDETECH
      Walla Walla, WA
      I had the same thing in my '68 Camaro with an LS3 and a T56.
      I ignored it.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Phoenix, AZ
      Thank you for the response. Unfortunately, it is a 3-bolt style, so no such luck on the measurement. I appreciate the suggestion, though.
      Mike -
      Thank you very much for your firsthand experience. Glad to know that maybe this is the design condition. Since you mentioned that you've ignored it, I assume this also means that you have not experienced any problems after-the-fact?
      Thank you both (again)!
      ~ Jason
      Walla Walla, WA
      Quote Originally Posted by Chevelle LT1 View Post
      Mike -
      ~ Jason
      It's too early for me to give you assurances that it's not an issue - my car's not on the road. That said, I can't imagine what issues might arise. If the shifter falls at a good point, the slight rotation of the tranny shouldn't be an issue. The T5's in some of the 3rd generation Camaros (maybe it was 4th) were rotated about 17 degrees from straight up.
      Jan 2009
      Tampa, FL
      Quote Originally Posted by Mkelcy View Post
      I ignored it.
      I too ignored it in my 66 Mustang/Viper T56. This is the 2nd time in a week of hearing someone with this problem. I made my bellhousing, when I clocked the trans behind it I set it up level, but then the trans mount was clocked a few degrees off-level. When I ma my crossmember I let to follow the path of least resistance.
      Jan 2007
      CT
      same here ... mine looked a little off but works fine.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      Phoenix, AZ
      Great, thank you all for the responses. At this point, looks like I will give it a shot and see how it turns out.
      May 2001
      Mesa, Az.
      Hmm. I have installed a number of T56s and haven't seen that one before.
      Phillip
      Do you have both dowel pins in place, and are they actually protruding into the trans front plate?
      I've seen the dowel pins push foreward during trans installation, and you can get the trans clocked significantly when this happens...your input shaft will not appreciate it.
      Crawl under and verify the dowels are in place and didn't push foreward.
      Sep 2009
      Ontario, Canada
      Got a Quicktime bell to mate to an LS-T56 and the transmission mounting pattern is rotated 5 deg. It matches perfectly to the LS-T56 Magnum I'm installing and puts the transmission mount horizontal. Since the shifter is basically centred, with it rotated 5 deg. toward the driver it seems to give a better shift knob position.
      Hope this helps.
      Duane
      '74 AMC Javelin AMX
      Phoenix, AZ
      Thanks again for the continued responses. Confirmed it before, but went and double-checked this morning: The dowel pins are definitely located correctly. I also finally have access to the trans mount, and have confirmed that it sits level. I think Duane and I are having much the same experience.
      Of course, though, I am now dealing with a new bout of strangeness on this job. The transmission is now clearly pointed towards the driver's side at the rear axle, and I can't figure out how that could have happened. Looks like I need to loosen everything and then try to re-seat it more centered in the tunnel.
      The fun continues...
      England
      If you can put a centre line down the car on the floor and use that as a datum and drop a plum line just in case the tunnel is out.
      May 2013
      San Diego, CA
      Wanted to bring this one back as I am having the same issue with my 67 camaro T56 install. Seems to be angled about 5 degrees toward the drivers side. Using a T56 magnum, Quicktime 8020 bell housing and LS motor. Others have this issue? If so, is it okay?
      Feb 2016
      Lawrenceville, IL
      Quote Originally Posted by SD67 View Post
      What you are experiencing is normal for that set up. When Tremec built the aftermarket T56 the "clocking" of the transmission followed from the OE side. Installing it with the Quicktime bellhousing should level the transmission mounting surface but will still give the transmission that 5 degree tilt.
      visit us on the web at www.bowlertransmissions.com
      Sep 2009
      Ontario, Canada
      X2. Standard install. If bell or adapter plate is designed for the LS Magnum, bolt pattern should already be clocked to suit. Puts the shifter in a bit better position for the driver.
      May 2013
      San Diego, CA
      I can see the utility in it but it sure looks out of place even with the mount horizontal. Thanks for the help, appreciate it.
      Apr 2007
      I am having the opposite problem, my shifter is level and my trans mounts is clocked, t56 magnum lsa with lsa bellhousing
