    Results 1 to 9 of 9
      Jun 2010
      spokane
      halfbreed slow but sure progress
      I got a power brake booster and master cylinder out of a 2000 camaro the booster and mastercylinder cost 36 $ at the local upull it yard . Ground off the rivets for the bracket . Removed the bracket from original booster welded old bracket to new booster. Cut pushrod and welded old style pushrod to it .
      I can say this isnt a bolt on but a pretty simple upgrade . I have the partial lines with the bubble flair fittings . The plan is to use factory components so if i have a parts failure it easy to obtain parts .I have the bubble flair tool and am running all new brake lines so i can use factory rubber lines hopefully .
      Also got some cts v brembo calipers and c6 rotors . However after a few emails with tobin at kore 3 i will get some 2010 camaro ss rotors . By the way if you have any questions regarding brakes tobin at kore 3 this guy knows his stuff and then some .
      If anyone wants info on the brake booster swap i will be glad to answer any questions . Its real easy and works with 4 wheel disc c5 and c6 brakes .
      When i start on the rotor and caliper conversion i will post pics also using coleman racing spindles i was talking with tobin about a hub for the spindles with 4 3/4 and 2.78 register instead of 5x5 with 3.00 register . i will post pics monday .
      Tim
      Lawrenceburg, TN
      Jun 2010
      spokane
      ok jeez already here is pics of booster
      It fits very nice and is small so leaves lots of room . I also took a picture of the rear tire 285/35/19 . For the pushrod on the booster i welded the rod ground it down then cut a 3/8 deep socket and sleeved it for added strenth cant be to careful .
      Jan 2010
      Goshen, Ky.
      I did the same on my 69 looks right at home.
      Lawrenceburg, TN
      nicely done Guys!! looks great keep the pics of the progress coming!!
      Jun 2010
      spokane
      For those that want to do this swap
      I posted a step by step in brake section .There are details i left out in posts in this section.
      Nov 2009
      AR
      sorry but what kind of car is this? Camaro?
      1972 Pontiac LeMans Luxury
      Jun 2010
      spokane
      Its an a body 1966 el camino kind of
      Its the same body style chevelle olds 442 gto and so on . This car is called halfbreed because its a el camino with gto body panels and drivetrain.
      Tim
      Jun 2010
      spokane
      Slower but still progress
      Attachment 41444Attachment 41443Attachment 41442Attachment 41441Attachment 41440I machined my hubs to 5.94 on brake lathe at work and got c6 zo6 rotors i ordered the calipers today . The 14 inch rotors are 68$ each right through gm parts direct . If you have access to a brake lathe and a micrometer machining the hubs is real easy . I was on kore 3 site and was looking at the 13 inch rear c6 vette brakes but not sure yet might just go with ls1 rears any opinions welcomed as to rear brake choice . I was going to do c4 suspension but decided this car needs to be on the road next spring so i will be getting a hold of marcus at sc&c for a stage 2 kit . Also put a pic in of rear tires 285/35/19
      Tim
