Results 1 to 17 of 17
desperately need to improve braking modulation/control...
first: just the facts, ma'am.
--stock sub
--front: air ride LCA's, SPC UCA's, air ride double adjustables.
--rear: air ride 4 link, air ride double adjustables.
--tires: 255/35/19 front, 325/30/19 rear
--brakes: 13.2"/ 6 piston front, 12.2" 4 piston rear, hydroboost, wilwood tandem master (can't recall bore--1.125"?)
--air ride front swaybar, no rear swaybar
I'm having what I believe to be just too darn much weight transfer under heavy braking--all four wheels lock at any sort of serious pedal pressure, and the back feels like a pickup truck in the rain. This may be aggravated by the hydroboost, but it seems to be proportioned correctly in controlled tests and I'm not sure, beyond that and without getting into swapping parts, what I can do to make things more progressive. Front shocks are two clicks from max on compression, rear shocks are four clicks from max on rebound. Front springs are at 90 psi +-2psi.
Anybody got any ideas? Maybe it's just terribly hard, sh*tty tires? Is there any way to back the hydroboost down without getting into new parts? I'm tempted to just rip everything hydraulic on the car out and start from scratch, as the clutch and brakes are both on-off-switches as of now. Either that, or rip the bags out and put coils in instead. Hell, maybe both?
Summary: if anybody has any idea of things I can do short of:
--better tires
--smaller bore master/switch to full-manual brakes
--cranking the shocks/springs up even higher
I will buy you multiple beers at RTTH or the next time you're in south carolina.
Edit: looking on wilwood's website, I have to track that master size down--if it's really 1 1/8", that's obviously problem #1 and switching down to something other than THE BIGGEST DAMN BORE THEY LIST ON THEIR WEBSITE will probably help quite a bit.
