Thread: CSB crankshaft treads
09-09-2010 #1
The treads in the crank is stripped about 1/3- 1/2 lenght. Is there a stud with 7/16 unf that i can use. From a main bearing kit or head ? If I use the original bolt from the engine it will be to short and i'm not satisified with using a bolt from the hardware store. if i can get oneor i have to machine myself from a UNC since highgrade UNF bolts in inches is not easy to get here in norway. If I can get a highgrade UNC....
Olav
09-09-2010 #2
- Apr 2008
- Newark, OH, / Concord, NC
- 497
Crank bolt
Call Stef's Pans, they also own B&B which is a bolt company, the number is 732-367-8700 or call ARP at 805-525-1497, either one should be able to fix you up with either a crank bolt or even a head stud or other kind of stud that will work, with a stud you can always order it a little long and cut it down to suit, make sure that you have some idea of what length you need before you call
DaleIF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
