    Results 1 to 15 of 15
    Thread: Dome Light???
      Dome Light???
      ANyone come across any nice domelights? I am getting ready to second skin before a new headliner goes in and want a better looking and brighter domelight.
      1967 Firebird 400 4 speed
      4 wheel c5zo6 brakes + hydroboost
      18"sterns wrapped in RE-11's
      Cornettsville, ky
      well you could pull something out of a newer car and use leds be cheap and sweet looking
      Jan 2010
      South Carolina
      i got a nice LED light bar out of the trailer section in walmart, it's for inside an enclosed trailer.
      it's about 6 inches long.
      it really puts out a cool blue light inside my trailer, i love it.
      recessing it some how would be cool
      bulb lights are not that cool, if you doing it, do it, and put some nice LEDs in it. maybe hide a whole kit for a motorcycle in there, that matches your exterior.
      Rural Retreat,VA
      I put a nice round unit from a caravan in mine
      Krist kustoms has a nice one if you still need it.http://www.kristkustoms.com/light.html
      Apr 2004
      OKC, OK
      clayton machine
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      El Paso, Texas
      Believe it or not, I have found some nice ones in mid 80's Fords. Lincolns and T-birds and some 80's F150's used a nice square one with two map lites that come in either chrome or body color. They are flat on the base which makes them very easy to mount.Pic attached.
      Apr 2010
      I just did a ridiculous amount of research on this last week and the market isn't that great if you want to buy new. For price, looks and lighting, I ended up with these. I haven't tried them out yet, but plan to tonight. They should be plenty bright - I plan to install them in the rear sail panels. If they work okay, I may put some on the front kick panels at a later date.
      http://www.etrailer.com/Trailer-Ligh...er/CPL33C.html
      Here are some more options....
      http://www.etrailer.com/dept-pg-Trai...or_Lights.aspx
      I ended up going stock, I'll see how bad it really ends up being and possibly address it with a bunch of led's inside the lens.
      Feb 2006
      Are the LED replacement bulbs any good for the factory dome light on old cars? The one that looks like a great big glass fuse.
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      El Paso, Texas
      I use LED bulbs from superbrightled.com and I like them. Plenty of brightness and they look cool as well.
      Used by professionals across the nation.
      http://www.lonestarpse.com/soundoff-...vdmltalcv.html
      Cornettsville, ky
      the best ive seen is the one in my 08 aura it is round but has tappable map lights for the rear
      Rockford Illinois
      I have an LED replacement I got online for cheap and it works just great so far. The amount of power my dome light was pulling from the battery was more than you would think and the new led is much brighter and whiter. I actually like the warm orange glow that the stock bulbs give but the power draw was a no brainer to conserve power. With LED tail lights the power the lighting system draws is cut substantially which helps the battery life.
      Cool blue light is what you get and you will either get used to it or go back.
      I used the base from a 2nd gen Camaro because it was round, picking the shape of the bezel is important to the other things in the car to keep a theme of shapes.
      Rural Retreat,VA
      I used a 95 caravan lamp, nice light just painted the trim flat black, also use GM rear viem with the map lights
