    Results 1 to 16 of 16
    Thread: POR then Liner
      Oct 2007
      Shawnee, KS
      POR then Liner
      Guys, I am using POR15 on the underside of the floor pans on my 67. I will be brushing it on. Do I spray on the liner when the POR is tacky or wait until dry and scuff?
      The destructions only list a topcoat paint, so I'm curious how you guys have done it.
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
      Dec 2007
      British Columbia, Canada
      If you check out my build thread, I used POR15 then a bed liner. POR states that for anything to properly stick to their product, you need to let it fully dry, then scuff it and apply their top coat primer. Once the primer is on you need to scuff it again and then you can apply the bed liner. I have a bunch of pics in my build of the process. When you're looking for their primer, it's called topcoat or tiecoat or something like that. It's on thier website and you should be able to get it anywhere that sells POR.
      Jun 2009
      Piqua, Oh
      I don't really want to contradict the previous poster, but I just used used this yesterday. On the label of the can it read you can top coat POR-15 after it dries 3-5 hrs. If you want to top coat later You can prime it in the same manner as above. Or after it has fully cured, sand it with 600 and use their Tiecoat primer.
      All the info is on their Web site.
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
      Oct 2007
      Shawnee, KS
      I've used the heck out of oven cleaner on the bottom of the car. Any additional prep needed besides the 2 POR chemicals?
      Shannon
      Bourbonnais, IL
      The only addition prep to the por15 is magic dust. Sprinkle that on and click your heels saying "i hope it bonds" 3 times. Sadly this isnt hollywood. Magic doesnt work. The POR will self peel in a few months.
      Oct 2007
      Shawnee, KS
      OK, what's your recommendation? My floor pans have been scraped and cleaned with some surface rust still there. Is there another product to help stop rust?
      Shannon
      Colchester, Ct.
      I have used Bill Hirsch Miracle paint...Warning don't get this stuff on you it takes week at least for the stuff to come off... Quick discription below the link
      http://www.hirschauto.com/products.asp?dept=3
      A moisture cured non porous paint that bonds to rusted and corroded
      metals like no other coating. It dries rock hard and will not chip, crack
      or peel. Impervious to gasoline, lacquer thinner, salt and most acids.
      Can be painted directly over rusted surfaces. Is strengthened by moisture.
      Will seal concrete, grout, wood, metal and porous tile like nothing else.
      Can be sprayed, rolled or brushed. Comes with disposable gloves
      and valuable product information sheet.
      'Veteran' --is someone who, at one point in his life, wrote a blank check made payable to 'The United States of America,' for an amount of 'up to, and including his life.'
      Bourbonnais, IL
      I dont really know what to use. I used rustolium. Not like I really trust it. But I have used POR WITH PERFECT PREP AS PER INSTRUCTIONS with failure every time. Chip and peel it away with fingernails/compressed air. Their metal ready is a good product though. Use that and some steel wool and it takes rust away easy.
      Now everyone quote me telling me how I have to prep with metal ready and marine clean etc.
      Dec 2009
      Quote Originally Posted by Satatic View Post
      So you left it rusty then? Moisture cured "paint" needs rust to cure well to a surface,it uses the moisture in rust to adhere to. You really have to leave it rusty, or it needs to be pitted a-la sandblasting.
      Dec 2007
      I've used POR15 on a quite a few pieces. Followed their procedure with marine clean and metal ready and haven't had any issues with peeling.
      oshawa ontario
      Quote Originally Posted by scherp69 View Post
      how long has yours been on there??
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
      Colchester, Ct.
      I have had great luck with the Bill Hirsch products... Wire brushed the rusty metal sprayed the metal and this stuff does't come off. I have used there tank sealer as well another great product.
      Feb 2006
      Might have to do a do-it-yourself liner. Line X would not touch my '66 'Camino bed because I put down POR-15. I explained that I took it down to metal first but it made no difference to them.
      Aug 2009
      SPI sells a pretty good liner along with a gun to spray it through. I've just sprayed their epoxy primer on the bottom of my chevelle and will be using their bedliner over the epoxy. No need to POR. You can also color their liner with 8 to 12 ounces of your paint, but it has to be mixed without any binders and added to the liner. Or you can use the black color that comes with it.
      http://www.southernpolyurethanes.com...ct%20lines.htm
      Jan 2007
      Yardley, PA
      I have the POR-15 on my frame on my DD wagon, 100 miles a day, rain or shine or snow. It has been there for 4 years and is perfect. just my experiance.
      Jul 2007
      Los Angeles, CA
      Same here, some places the paint has been on for 2+ years now.
      Its all in the prep and the prep is hard to get it completely clean, but like most things you get what you pay for. Try hammering or wiping down other paints with Lacquer thinner, both of which you can do to a cured Por-15 surface with no ill affects.
