    Results 1 to 9 of 9
      Melbourne, FL
      (pics)global west upper a-arm issue ??
      I just started to FINALLY install the front suspension on my 67 'Bird. I started with the upper control arms. I have Global West tubular arms with the Del-A-lum bushings. bushings. I started with the passenger side with no issue. But, when I went to install the drivers side I discovered that the inside part of the rear bushing was making contact with the control arm mount. It wouldn't allow me to tighten up the not on the mounting bolt. It looks like the control arm is installed too far forward on the shaft. Is this possible?? My wife has our camera in her truck. Once she gets home I'll post some pics of all four mounting points of the controll arms so you can visually see what I'm talking about.
      Logic says I can loosen the front nut and tighten the rear nut to adjust the clearence and get the arm better aligned on teh shaft. But logic doesn't always play out properly in these sort of things.
      Any thoughts or feedback would be appreciated.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Melbourne, FL
      Ok here are some pics. They are as follows:
      Driver's rear - Where the contact is made.
      Driver's front, Passenger front, and passenger rear.
      Templeton, CA
      The only issue that I could possibly see happen is allowing enough room for the cotter pin. Other than that, I see nothing. I'll be watching this to see what happens. I just did the G Mod to mine and now I'm thinking of tubular upper A arms. yeah, I already cut the mounting ears off! oh well can't tell unless you're looking for it.
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
      Damascus,MD
      Here are pictures of my 67 Firebird with GW upper arms. As you can see clearance is good. I don't think you can loosen and tighten the shaft nuts to center the arm. The shafts have shoulders. It seems to me your upper mounting holes are shifted. Production tolerances? Maybe.
      The Dr.'s 1st law of auto repair: When the need arises,any tool or object closest to you becomes a hammer.
      May 2002
      Northern California
      Quote Originally Posted by 67 455 Bird ragtop View Post
      you should be ok once you get a nice stack of alignments shims in there.
      sometimes you have to trim the mount if the g mod has been done.
      also keep in mind that the arms go up quite a bit when at ride height.
      vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Central CA USA
      You will have at least one or two shims in there once it's aligned.
      It's hard to see if it's hitting along the tube, it it is, you can probably bump the bracket sides back with a hammer a little.
      David
      Sep 2001
      Accord, NY
      Ah yes, production tolerances. The mounting holes on my 68 differ by 1/4" causing the same interference you have, just on the opposite side. With alignment shims it lessened but I also used my die grinder to slightly clearance the edge. As a point of reference, I have 1" of shims in the front and 3/4" shims in the rear to get -.75 degrees camber and positive 5.25 degrees caster.
      68 camaro - SOLD
      Melbourne, FL
      I forgot about the shims. I'll see if I can find a few to give a little clearance to finish the install.
      Mar 2010
      Costa Mesa, CA
      Yes, As others have said, the shims (most likely even a 1/16" shim will work) will solve your problem.
