    Results 1 to 9 of 9
      Ca
      A little 340 Duster...
      Hey Gang,
      Mostly a lurker and searcher. I find the level of cars just amazing on this forum. That being said I would like to introduce my newest project. Live in the O.C. and work for aFe Power.
      I have some grand planning to do so I thought I would share a little to maybe get back some inspiration from my fellow enthusiasts.
      The car: 1973 Duster 340 4spd.
      The goal: A 410 stroker, EFI, 4spd A833 overdrive, 17's wheels and 8.75.
      What I I have not decided on: Paint, rear axle set up or tire size. I am kind of thinking keeping red with black hood treatment and dark gray front suspension parts and motor with black accessories. The red color I have a h*rd-on for is the 2010 Porsche Cayenne GTS Red. The duster was originally red with black interior. I saw a Cayenne the other day in GTS Red and thought perfect! A little modern twist without too much variance, the Cayenne paint looked solid pigment non-metallic but I am not 100% sure. So there you go just planning away right now. I thought I would share some photos and kick some ideas around. Any tips or tricks would be great. I bought the car without and engine or transmission for a fair price. Check out the pics
      Albemarle, NC
      theres a few of us dusters on the site. some going further than others.
      on the rear axle, with what you have planned, id go with a rebuild 8.25. put some 3.73 and a limited slip, use the grand cherokee rear disc, and roll with it.
      mustang bullitt wheels fit with a little effort, and get you cheap 17's.
      also, a 73, 340 4 speed car. it looks fairly rust free, but rather incomplete. good luck with it. any questions, let us know. we can probably help. also, look at www.forabodysonly.com
      lot of us kind of guys over there, too.
      Michael Crawford
      Dec 2007
      PA
      Looks like a great start. I love these cars. I remember riding in one when I was a teenager going about 113 miles an hour in a straight line and had a feeling that the car was going to float of the road. Any plans for the driveline / suspension?
      Project 69 Camaro: Chassisworks G-Bar, FAB-9 & sub-frame, Fesler Billet, ISIS wiring & LS3!
      More pictures: http://camaro69vn10.com Updated!
      Used to be known as Camaro69vn10
      Jul 2010
      Country Flag: North Korea
      Quote Originally Posted by MichaelUser View Post
      Hey Gang,
      Thats a nice starting point. It looks like we're gonna be building similar cars. I've got a 73' 340 clone(360 under the hood)
      As for the axle if you're starting from scratch and want something tough & not too expensive, why not look for a ford 8.8? i've heard the ford rangers are the right width and it just needs mounts moved.
      I went 8.25 because i got one dirt cheap, but an 8.8 was gonna be my next option.
      Ca
      Quote Originally Posted by DartorDemon View Post
      That sucks for the me because I just sold, just last year a 8.8 from a Exploder. Disc brakes and all.
      If I can find a 8.75 housing I will have the Ford Exploder disc put on it with the nice drum style parking brakes. I always hated those GM style calipers. They always seem to drag the pads more then needed. Even with the factory adjustments.
      Ca
      Quote Originally Posted by markd View Post
      I am still planning going a 340/360 stroker. If I can go with a LMHemi then I might do that instead. I found a 5.7 from a GC long block for cheap, but it took on water and threw a rod.
      The damn 340 block are around but are getting harder and harder to find.
      Since mine is a factory 4spd, I would like keep it manual. The ideal tran s would be a Tremmec, but I could survive with a A833 overdrive unit.
      Apr 2008
      Lakeland, FL
      Good to see another duster on here!! I have an A-833 O.D. in my duster rite now. Its good for the streets, maybe autocrossing too (youll be in 2nd gear all day), but at the drags i think im losing nearly 3/10 of a second because of the gearing; 1st gear is useless in all of the above scenerios..id either look at passon for different gearing, a tremec 5spd, or rebuild a blown t56 like im planning on if you dont mind tearing up the floor. good luck with everything, cant wait to see what direction youll be going with everything!
      Tim
      71' Demon-408, efi, 'viper spec' T56, Dana 60 w/ triangulated 4 link
      Jun 2009
      NY
      Nice starter car. Thats going to be a cool project.
      good luck with the project!
