    Results 21 to 40 of 49
      Houston tx
      68 camaro almost done
      Well i am almost done with my camaro after a month straight of working on it every moment i'm not at work. I started at the bottom. Took all the suspension out and apart and wire brushed the underbody from the front bumper to the back. Repainted all of it with the rust proof black paint, put in prothane bushings in the upper and lower a arms, sway bar, rear leafspring eyelets and new hangers, body mounts, engine and transmission mounts. New ball joints, new shocks and eibach springs on the front. New shocks on the rear, comp engineering rear shock relocation kit, comp engineering traction bars, comp engineering subframe connectors, new willwood 12 inch front disk brake conversion, wilwood braided brake lines, all new hard lines, wilwood master cylinder, gm 11 inch rear disk brake conversion, new rearend axle and pinion bearings, 3.42 gears, all new seals, boyd 17x7 and 17x10 billit wheels. stripped interior to metal and wire brushed and repainted it all as well. Put in two layers of dynamat from firewall to back of trunk, including the doors. new carpet, new black leather reclinable racing seats with 4 point harnesses, lokar billit pedals, billit window cranks, billet rearview mirror, billet gt grant steering wheel with billit adaptor. put new seals in the saginaw 4 speed. 12 inch centerforce dual friction clutch. Engine should be done at the machine shop today so i can put it together and in the car to be driveable by friday. Engine is the stock 350 block, eagle 383 stroker crank, scat 4340 H beam rods, speed pro forged flat top 2 valve relief pistons, brodix track 1 heads, harland sharp 1.5 roller rockers, comp cams xr288hr cam, comp cams lifters and pushrods, cloyes double roller timing set, ceramic coated long tube headers, 2.5 inch bolt in exhaust system from the headers back. Saved my parts up for this project for the last year and now putting them all on at once. Will hopfully be driving friday, then start saving to get her painted. Will post pics of all i've listed asap.
