      Nov 2009
      AR
      Oil Pan Change 72 LeMans
      Easiest way to get to the oil pan to remove old & install new pan.... Tips, secrets, thoughts, opinions...?
      My oil pan is literally beat up. Dented to hell and back. Needs to be changed out, so help me out if you can!
      1972 Pontiac LeMans Luxury
      I'd probably pull the motor.
      Matt Field
      1967 Pontiac GTO.
      Feb 2009
      muggy midwest
      You should be able to pull it easy enough without pulling motor...I dropped the pan off my 70 Monte with no hassles way back in the day-I have a bad timing chain (stock) and I dropped the pan, cleaned it out, pulled the timign cover, put a new chain in, installed new oil pump and sealed it up with a 1-piece Fel-Pro oil pan gasket. Took me about 4 hours total and I just had the car set up on ramps up front and stands in the rear. Your Poncho 400 motor may require pulling engine to get the pan off but I doubt it-A-body engine cradles have plenty of room between them and the oil pan. If you have at least 2.5" clearance I'd say you can do it with motor in car.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      So Cal
      By the time you disconnect everything needed to get the engine high enough to get the pan out, you might as well just pull it all the way out and do it on the engine stand where you can get the pan to seal up right.
      Or you can struggle laying on your back with the engine sitting halfway out of the engine compartment, hanging from your hoist.
      The oil pans on Pontiac A-body cars don't come out easy at all, do yourself a huge favor and pull the engine.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Jun 2005
      Little Rock, AR
      Swazall! OR, LSx swap!!!!!!!!!!!!!!!
