08-24-2010 #1
- Aug 2010
- 2
Wilwood master cylinder/bleeding issues
I'm having an issue with my Wilwood master cylinder. The car also has the 4 piston Wilwood dynalite calipers.
Pretty much nothing comes out when its mounted on the car and the pedal is pressed.
Took it apart and all the seals and pistons look fine.
Not sure whats up, or if i'm doing something wrong.
I tried to bench bleed it again today.
Looks like I can actually get fluid to come out of the hoses. Bubbles would come out of the tubes that were going back in to the resevoir and stopped after about 5 minutes of manually pressing the piston.
Thought all air would be out so I hooked it back up on the car and nothing..
The pushrod seems to be the correct length aswell.
What exactly is the procedure to hooking up a bled master to empty brake lines and then bleeding?? If I depress the pedal and get someone to open the bleeder the fluid level doesn't go down at all. Wilwood 4 piston calipers with 2 bleeders on top. The instructions on the wilwood website seem to suck.
mike
08-24-2010 #2I'm having a similar issue with my new willwood master. I'm drawn the fluid to the rear of the car with a vacuum bleeder and I can't get any fluid to the drivers rear, even at 20-30 psi.
1967 Firebird 400 4 speed
4 wheel c5zo6 brakes + hydroboost
18"sterns wrapped in RE-11's
08-24-2010 #3
- Jan 2006
- Oregon
- 1,773
