    Thread: Hood Hinges
      Jun 2005
      Hood Hinges
      Hello
      I hope I explain this the right way.
      Adjusting the hood hinges so the back of the hood goes down without having to push the corner where the hinges are down?
      This is on a 68 Chevelle Fiberglass hood, stock hinges. Also having same problem with a 72 El Camino & 70 Nova.
      Is there some trick to setting hinges?
      The corners by the hinges don't go all the way down when I shut the hood. I have to push each side down for the hood to lay flat.
      Any suggestions?
      Rob
      Aug 2005
      Hamilton, NJ
      Scott from NJ.
      Vent Windows Forever! ...
      Sydney, Australia
      Country Flag: Australia
      Sounds a lot like the hinges are worn.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      Jun 2005
      Thanks alot. I'm going to give this a try. Hopefully I can get it right.
      I have all new hinges. I was debating on buying DSE Billet hinges, To see if it made a difference.
      Thanks again
      Rob
      Oct 2009
      So Cal
      Try taking off the cowl rubber.
      Big Block Killer
