    Thread: Idle Problem
      Jul 2010
      Idle Problem
      Good Morning fellow muscle car enthusiasts.. i have an idle problem, when i cold start my car it dies unless i take off immediately... throughout the day it will start fine.. I have changed the mass airflow and idle speed sensor.. now im stumped.. its a 2001 pontiac trans am ls1... thanks for your help
      May 2002
      Northern California
      double check for bypass air from the mass airflow meter to throttle body and also check the throttle blades for carbon/oil build up. might need a cleaning.
      was your battery disconnected recently?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2010
      thanks
      i tried the battery idea we will see how it works in the morn when i cold start... ill check the other two in the morning as well... ill get back to you thanks!
