      Oct 2006
      McKinney, TX
      Curing portland cement
      HELP!
      I know this could have just as easily gone in "off topic" but it is kind of time sensitive...Anyone who knows concrete, please chime in!
      I put in a slope to my garage entrance(about 2 inches high, 11 inches long). Given that it is 105 degrees here in Dallas, I let it set for about an hour, sprinkled it with water and then covered it with plastic so it wouldn't dry too fast.
      How long should I keep the plastic over the cement? I know that leaving it wet too long is just as bad as drying too fast...
      Thanks!
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Dec 2009
      El Dorado Hills
      First off, a 2" section of concrete over concrete is not going to last very long, especially with the heat you get out there. Secondly, you want to use a wet blanket, not plastic.
      If you have just placed the concrete, you can buy a curing compound to spray over the top of it. Curing compound acts as a membrane and depending on brand, in hotter weather you typically apply it when there is no more sign of moisture. In cooler weather I typically wait till the next day. The curing compound will also keep the concrete from soaking water which if the concrete you placed is to pourous will eventually deteriorate.
      If I was desperate and wanted to place concrete the way I think you did, I would have placed some sort of chicken wire to act as rebar then after it cured used a curing compound.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
