    Results 1 to 10 of 10
      Jan 2010
      Perth, Australia
      Country Flag: Australia
      Baer Pro Plus 6P - Which MC
      Hi Guys,
      I just fitted a complete set ( front and back) of Baer Pro Plus 6P on my 69 Camaro . When I first got the car it had C5 set up at the front and early 80s Cadillac discs at rear, with the original 69 11" booster and disc / drum master cylinder. This set up was pretty average, and i'm pretty sure that the MC set up was incorrect the brakes.
      I have searched high and low on here and other forums for the correct master cylinder set up for the pro plus, and from what I can gather I should go for a 1-1/8" bore master cylinder based on similar set ups. However, I have based this on the Wilwood and Baer set ups - 6 pot fronts and 4 pots rears. I just want to confirm before ordering a new Wilwood MC.
      I have also emailed Baer and haven't received any feedback as of yet.
      I would also like to thank all for the wealth of information available here.
      Cheers,
      Lyndsay
      Go Hard or Go Home
      I went with DSE- booster - master combo- they say it works great with all the Baer products- we'll see
      Jan 2010
      Perth, Australia
      Quote Originally Posted by youthpastor View Post
      Is that an 1-1/8" bore unit.
      Cheers,
      Lyndsay
      Go Hard or Go Home
      Oregon
      The DSE setup is a dual-9" booster with a 1" bore master cylinder IIRC.
      Post up your caliper piston sizes...I'd be willing to bet that you do not want to run a 1-1/8" bore MC unless you've got a hydro-boost hiding under the hood.
      Tobin
      KORE3
      It's what I does.
      Dec 2009
      Hope this helps --
      I spoke w Baer a couple of weeks ago. Same set up and I already have a 7/8" Wilwood master. They said to try that, that optimum would be 15/16". Wilwood only comes in either my size or 1" and 7/8" (I believe) and in a manual application would give better feel at the pedal...
      I'd like ot hear Steve Rupp chime in here, he went though this recently and I'm wondering what he's running today. I think BOS told me he tried both sizes.
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Jan 2010
      Perth, Australia
      Thanks guys. The calipers have the following specs:
      Front 6-piston diameters are 1.625 / 1.375 / 1.1875"
      Rear 6-piston diameters are 1.1875 / 1.125 / 1.000"
      I guess my options are to run with the 11" booster and get a new 15/16" or 1" booster or run a complete new DSE set up. Does this sound right.
      I would prefer the booster option to have a lighter pedal
      Cheers,
      Lyndsay
      Go Hard or Go Home
      Oregon
      Given the piston diameters provided above, the fornt and rear caliper areas are as follows:
      6P front = 4.664 in^2
      6P rear = 2.886 in^2
      These calipers have about 16% more piston area than a similar C5/C6 kit front and rear, so for similar pedal feel, you would want to use a MC bore approximately 1/16" larger. Pad compound certainly plays a part as well, however as a general guideline I would suggest a 15/16 to 1" bore for manual applications, 1" to 1-1/16" for vacuum boosted and 1-1/8" to 1-1/4" for hydro-boost.
      Tobin
      KORE3
      It's what I does.
      Jan 2010
      Perth, Australia
      Tobin, Thank you so much for taking the time to sort this out for me.
      I think 1" should be sweet
      Cheers,
      Lyndsay
      Lyndsay
      Go Hard or Go Home
      Central CA USA
      We put those brakes on Bad Penny, first master was the fancy Aluminum Willwood 1" bore, - manual brakes. The pedal effort was a little high so Steve switched to the 15/16" (.88) bore version which works great. This is all on a 14" rotor system.
      David
      Dec 2009
      Quote Originally Posted by David Pozzi View Post
      David
      Thanks for the info David. I have the same set up. Questions for you - was the 15/16 a Wilwood unit? Do you think my 7/8 will work as suggested by Baer?
      Sorry for the hijack!
      Ron in SoCal
