      Phoenix, AZ
      Hard Brake Line Install Question
      Sorry, no photos to explain my situation, so I hopefully can get everything conveyed verbally: I am plumbing the hard lines for my front brakes. The LH and RH hard lines will plumb into a T fitting, with the 3rd port directed to the master cylinder. Here's the question: At the T-fitting, does it matter which ports I use for the LH and RH lines, or will there be even pressure on both lines no matter which combination of ports I use? Normally, I would try to use the ports on opposite sides of the T-fitting for the LH and RH lines, but that will make it more challenging to get the lines run in this case; right now I am looking to use the adjacent ports for the front lines.
      Thanks for the help!!
      ~ Jason
      May 2010
      Orange, CA
      In a hydraulic system the pressure will be the same at all ports
      Phoenix, AZ
      Thanks, Don. Appreciate the confirmation, it was consistent with my understanding/expectation.
