Thread: C5 Corvette MC
08-14-2010 #1
- Feb 2007
- USA, TN
- 850
C5 Corvette MC
I've installed a set of Wilwood front brakes with 4.04 inches of piston area and now I have very little pedal travel. I'm going to replace my C2 1.125 inch Corvett MC with a C5 1 inch MC. I'm also thinking about installing a Wilwood distribution block/proportioning valve.
My questions are
1. How do I adapt the 10MM inverted flare fittings to the 3/8 inverted flare on the Wilwood proportioning valve?
2. Will it bolt directly to my 71 Nova vacuum booster?
3. Am I better off using a 98 - 02 Camaro booster and 1 inch MC? The lines exit on the left, but I can work with that; however, it is still has 12MM fittings.
