      Feb 2008
      Melbourne, Fl
      body bushing help?
      I have a 68 camaro and im putting the body bushings on and need to know if the thicker bushing mounts in the back part of the subframe or the middle? I have no paper work. any help would be good. thanks
      Feb 2008
      Melbourne, Fl
      any one? someone has to know.
      Mountain Springs, Texas
      Do a search over on camaros.net
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      I always thought the middle and rear mounts were thicker than the core support. You only have one set thicker than the other two?
      Feb 2008
      Melbourne, Fl
      I will be going to solid mounts later but the set of rubber mounts i have the middle and rear are to diff. thickness. maybe a bad set? and the core support bushing i cant mistake which ones those are.
      May 2002
      Northern California
      Quote Originally Posted by 68Formula View Post
      thats where we have always put them ( when we used to use them). It might be dependant on the manufacturer. It would help to know which brand.
      https://www.pro-touring.com/forum/sh...ing#post660636 see here....for Global west solids
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Orlando, Fl
      The oddball pair go on the core support. The back 4 are the same. Whichever is the oddball (thicker or thinner) go on the core support. It is all manufacturer dependent.
      Nick DiPrenda
