    Results 1 to 13 of 13
      Hydroboost fittings
      what size and type of fittings are on the gm hydroboost the same type hydratech uses?
      1967 Firebird 400 4 speed
      4 wheel c5zo6 brakes + hydroboost
      18"sterns wrapped in RE-11's
      Orlando, Fl
      Borrowed from Hydratech's site. This lists all the outlet fitting sizes.
      HYDRATECH 9103 AN-6 BANJO FITTING SET
      * 2 Piece Design 5/16-24 O-ring Male to 3/8 Male Hose Barb Return Line Adapter
      * Surface Seal Type Adapter with O-ring Seal
      * 18mm x 1.5 Metric to AN-6 Male High Pressure Inlet Port Banjo Fitting
      * 16mm x 1.5 Metric to AN-6 Male High Pressure Outlet Port Banjo Fitting
      * Zinc Dichromate Plated Mild Steel Banjo Bolts and Fittings
      * Fits most all 1980 and newer Bendix Type I and Type II hydraulic brake assist units
      About 3/4 of the way down the page:
      http://www.hydratechbraking.com/prod...cessories.html
      Nick DiPrenda
      Apr 2004
      OKC, OK
      factory setups use inverted flares. hydratech uses adapter fittings to convert to AN
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      thanks guys... I guess I should of looked harder... but helping one another is was a forum is all about right...
      what about the ps pump and gear box?
      Apr 2004
      OKC, OK
      same thing, fittings to convert to AN
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Orlando, Fl
      Quote Originally Posted by LONE*STAR View Post
      Are you asking what size the fittings in the box and pump are??
      Nick DiPrenda
      yup
      I'm trying to save a few bucks by doing the whole setup out of hydraulic lines... thanks nick
      Orlando, Fl
      I do not know what the pump is to be honest. The box though... What kind of box are you running?
      Nick DiPrenda
      stock box and pump the pump only has one input
      Orlando, Fl
      Stock box should be these as long as your box is original:
      One fitting at 5/8"-18
      The other at 11/16"-18
      Both inverted flare.
      Forewarning... Later boxes went Metric.
      Nick DiPrenda
      Orlando, Fl
      I really don't know what the pump would be. I wish I could help you there.
      Nick DiPrenda
