      NJ
      tko 600 hydraulic
      Has anyone changed the hydraulics back to mechanical linkage on a tko swap. Does the input shaft / hydraulic slave mount have to be changed back. The hydraulic feels low and my buddy wants to swap to mech. It is in a 71 Chevelle. Maybe I can get some quick answers.
      thanks
      -Tom
      Tom
      We don't sell mechanical linkage any longer but you can get it from one of the sponsors here or True connections 800-600-4144 or The Original Parts group. If you want to go back to mechanical you'll need a fork, throw out bearing, and linkage. The stock bearing retainer must be used for a stock throw out bearing so depending on what style of hydraulic throw out bearing you have you might need to put the stock retainer back on. If it's a slip on bearing you would just remove it and put the stock throw out bearing on.
      Hope this helps.
      Jim
