    Results 1 to 17 of 17
      Feb 2009
      Perth Australia
      Country Flag: Australia
      Ballistic Take 2
      So after a 3 month wait i finally got my Camaro about a month ago. I havent really done anything to it since it landed here except to unpack the car of all the parts and bolt on the bonnet.
      Specs:
      572 Donovan alloy big block
      T56 transmission
      4 inch carbon fibre tailshaft
      Currie 9 inch
      CCW 3 piece wheels with 265 fronts and 345 rears
      Art Rassmusen subframe
      C4 uppers and lowers
      Customs 4 link with panhard rod
      Baer 14 inch 4 piston front and 12 inch 2 piston rear brakes
      Not sure what iv got myself into but will start sorting things out and work out what direction i want to go. Probably the first thing i will do is to convert it to RHD and then finish all the fab work. Then i guess will start runninig fuel and brake lines and re wire it. Not sure what wiring harness to use, i am open to suggestions there. The manifold has been plugged for injectors so i may as well get a throttle body and computer (again open to suggestions on which to use). Everything else i guess i will just work out as i go along. Im probably not going to do a whole lot to it this year as the funds are a bit low but hopefully it will be on the road by end of next year.
      Luke
