    Results 1 to 11 of 11
      Aug 2006
      florida
      brake bolt ?????
      So my car has the Baer rear rotor upgrade ( stock calipers) any way the top bolt the holds the caliper to the bracket decided to " dissapear" ?? don't ask how I'm not sure. I went to my local ford dealer and got new bolts, they are about 1/2 inch shorter than the bolt that is still there{ because of the bracket that extend's the stock caliper out} , you guys think maybe putting some locktight and the shorter bolt would be ok, or should I try and get the same length bolt ?????? thanks for all & any thoughts.
      Jul 2003
      Anaheim Hills, CA
      Kind of depends.. how much of the bolt is in the hole?
      In other words does the shorter bolt go all the way though the threaded hole?
      1968 Track Rat Camaro:
      Aug 2006
      florida
      no, it looks like maybe half goes in
      Aug 2006
      florida
      maybe a little more than half
      Aug 2006
      florida
      the longer bolt stops even at the end of the threaded hole,
      Mar 2010
      AZ
      Get the longer bolt, and make sure it's a grade 8 or better, 10.9 would be much better. Your brakes are one thing not to fool with. And I would blue locktite them too, I always do on brakes.
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by ArtosDracon View Post
      What he said..
      That caliper bracket is under HUGE stress. I had a bolt work it's way out of my wilwood setup at Buttonwillow.. let's just say that when the other bolt sheered off it wasn't pretty.
      Get a longer bolt of the best grade possible and use a dab of red loctite.
      The shorter bolt could get you home in a pinch, but I would swap it as soon as possible. You need it to go all the way through the threaded hole.
      Mar 2010
      AZ
      Quote Originally Posted by Steve1968LS2 View Post
      Yikes!
      That's a and hope no one notices that your pants are wet when the car finally stops, type of situation.
      Orlando, Fl
      To avoid any confusion with this info...
      Grade 8 is a classification associated with SAE fasteners.
      10.9 is a classification associated with metric fasteners. Metric fasteners have a higher strength classification available as well (12.9).
      Nick DiPrenda
      Mar 2010
      AZ
      Quote Originally Posted by dipren443 View Post
      Thank you for that, I had forgotten the difference was SAE vs Metric. Isn't there a grade 9 for SAE besides the ARP chromoly that's rated to 180K?
      Orlando, Fl
      Yes, there is a Grade 9. They aren't very common, so I didn't even bother mentioning it. It isn't just for ARP. These standards are driven by SAE, but unlike Metric 12.9, SAE Grade 9 isn't very common.
      If you had to have some Grade 9 hardware, I would look at aircraft suppliers.
      Nick DiPrenda
