      Jul 2008
      Quarter pannel alignment?
      I am down to the skeleton on my car and am told i need to put suspenssion under it before puting all of the new sheet metal on? Right now it is on a cart that i built with good bracing. Just like i see on other projects.
      So do i need to wait for suspenssion to get here?
      Also, Can i put body filler over DP90 epox primer or does the filler need to be on bare metal ?
      Thanks..
      Mountain Springs, Texas
      Lots of guys install quarters on a body jig without issue. Should be fine if all the pickup points are tied in.
      Filler over epoxy is a good way to go. Filler on bare metal sometimes leads to problems because the filler can absorb mositure and cause rust. Make sure you scuff the epoxy before applying filler over it.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
