      Oct 2002
      Houston,TX
      Easy grill question
      I cant seem to find this but on a 69 camaro do the plastic bolt tabs on the grille go over or under the tab on the headlight mounting bracket? I took off so long ago I cant remember...
      James J.
      Rockford Illinois
      If i remember right it goes over the top. Plastic in between metal usually doesn't stay tight.
      I brought this to the top so maybe someone with a 69 will answer. Also it makes a difference if it is a standard or RS, so wich is it?
      Feb 2006
      Spring Texas
      The plastis goes over the metal bracket / clip.
      Mike
      69 camaro, 502 w/8-71 blower, street car
      http://s268.photobucket.com/home/pro...69camaro/index
      Oct 2002
      Houston,TX
      thanks, thats what i thought but wanted to make sure
      James J.
