      Apr 2010
      Israel and Rockville, MD
      69 firebird engine mounts for chevy engine
      the previous owner did some lame plates to hold the engine mounts for the 383 chevy stroker i got right now.
      the frame is the original 69 firebird frame but the mounts are 2nd gen mounts.
      what i want to know is the 69 camaro has the exact frame? if it does how do i mount the mounts on the properly and not with half bolted plates... the engine block is from 85 but if i change the mounts of the frame and the block it should line up properly?
      this is how it looks right now.
      69 Firebird - 383 chevy
      http://www.rbtec.com
      May 2002
      Northern California
      it should...pull all that off and post a picture. should have three holes for these brackets.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Apr 2010
      i can't take them off because the frame is already on the car.
      i was hoping someone has the knowledge to help.
      can i retrofit 69 mounts to newer block for sure?
      Mountain Springs, Texas
      Same subframe is used for Firebird and Camaro. The Chevy mounts should bolt right on.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jun 2009
      N.Nevada
      cheviac or Pontrolet
      thats right......maybe put a pontiac back in ?
      462 Doug Nash 5 Speed Centerforce Clutch Quicktime Bellhousing Edelbrock Heads Solid Roller Holley HP Victor Intake Pump Gas 66 12 Bolt Poly Bushings Hotchkis Springs Metco Control Arms Big bar front Stock rear bar INTRO 20's & 19"s
      Apr 2010
      i prefer my chevy 383 stroker
      the other thing i didn't get an answer for does the other side of the mounts, the part that attach to the engine block can bolt to a 85 350 block the same as 69 350 block?
