    Results 1 to 9 of 9
      Jul 2009
      Ames, IA
      Need LED Lights for Chevelle's
      Guys,
      What would you recommend for LED tail lights for a '64 Chevelle? I've never done an LED swap before.
      While I'm at it, what do you guys run for modern headlight systems?
      -Rob Kibbe
      May 2008
      SoCaL-Pico Rivera
      Nov 2001
      St. Cloud, MN
      Dakota Digital has em. Due to the optics in the original lens a single emitter LED works best.
      http://www.dakotadigital.com/index.c...rod/prd546.htm
      Jon
      71 Nova LT1/4L60E
      Jul 2009
      Ames, IA
      Dakota Digital looks good - thanks!!!
      -Rob K
      May 2007
      Las Vegas
      for headlights, look for an H4 conversion, use some relays and heavy gauge wire...
      Rich
      1969 Camaro (in hibernation)
      Southern Indiana
      I put a set of 360 degree high intensity bulbs in for a guy the otrher day in repro lenses in a Camaro, like 78 or 79. We have them a Pep Boys for like $19.99 or $29.99 each, they are blinding if not installed and very bright in a clean lens. But do take a special (ie electronic flasher).
      But if you got cash a Dakota does then thats ok too.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Fort Worth, Tx
      I know a couple places offer the 7" crystal clear lens for Camaros and Mustangs but I have yet to see someone (board vendor) offer something modern for the early Chevelle 5 3/4. I could be wrong though. I'm looking too.
      Jun 2009
      N.Nevada
      maybe this ?
      462 Doug Nash 5 Speed Centerforce Clutch Quicktime Bellhousing Edelbrock Heads Solid Roller Holley HP Victor Intake Pump Gas 66 12 Bolt Poly Bushings Hotchkis Springs Metco Control Arms Big bar front Stock rear bar INTRO 20's & 19"s
      Erie, PA
      Are 64 similar to 67? If yes, check out
      http://www.shiny-hiney.com/home.html
      Andreas
      www.fgmcc.com
