    Page 2 of 2 FirstFirst 1 2
    Results 21 to 39 of 39
      Nov 2000
      O-town
      I have mine installed, and it's very visable the area Blake is talking about, tonight calls for a rotor check, maybe I'll try to throw up a pic,
      IL/TN
      BTW Mr. engineer there is no way you could press fit a stud with nearly 1/8" interference without distorting or cracking the hub, one thing I take offence to is narcissistic engineers that think they can pull the wool over other people's eyes.
      https://www.protouringf-body.com "doing what they say can't be done"
      Nov 2007
      Quote Originally Posted by 79T/Aman View Post
      But he's not just ANY engineer, he's Mr. Engineer.
      Jun 2008
      Western Washington
      I'm not sure I can deal with having 12mm and 1/2 studs front to rear, just a "MENTAL" thing.
      So I called the ARP Special Order group and explained this situation and let them know if they made a 1/2 stud that had a .509 knurl diameter they would probably sell like hot-cakes.
      I know the .509 dia is small and not nearly as strong as the .625 knurl dia of the 7703's but it would eliminate the need to have any machining done.
      I'll update when I get an answer.
      "Step Brothers"
      Pro Toured 95 Pontiac Trans Am (Green Dragon)
      Full Frame Build 69 Camaro (Night Hawk)
      -Luca Z
      Aug 2001
      Connecticut
      I've got possibly a dumb thought, could there be any problems from the GM 120mm bolt circle vs a 4-3/4" rim bolt circle (.026" difference) ? Or are the bearings special ordered on 4-3/4" bc?
      While reworking the hubs it would seem like a logical time to fix the bolt circle too, correct?
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Oregon
      Quote Originally Posted by 68sixspeed View Post
      The C5/C6 Corvette wheel pattern is 5x4.75, not 5x120.
      It's what I does.
      Aug 2001
      Connecticut
      Quote Originally Posted by Apogee View Post
      that's good, I had been told by another vendor that they were 120mm, but you are correct, I searched and found 120.7mm = 4.75" ... solves another question on another project!
      2006 Corvette Z06
      St George Utah
      did we resolve this issue Mr Engineer.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Jun 2008
      Western Washington
      I have always seen the bolt pattern referred to as 5x4.75 or 5x120.65, so it is a "square" 5x4.75. It's just VERY confusing why GM does a 5x4.75 bolt pattern with a 12mm stud????
      I asked ARP special order group about just threading their 7708 and 7713 with 1/2-20 instead of the 12mm-1.5 but they were not very receptive since I would only be buying 10 of them.
      They might consider it if a vendor contacted them and could buy a couple 100-1000 to sell to us....
      I have been seeing torque specs for 1/2" lug nuts is 80 ft-lb and 12mm lug nuts is 90 ft-lb from a couple different sources. Is this what others have found? It seems opposite?
      "Step Brothers"
      -Luca Z
      San Antonio, Tx
      GM says 100ft-lb on all of there cars with 12mm studs.
      Instagram: CamaroAJ
      St George Utah
      Quote Originally Posted by CamaroAJ View Post
      your refering to the wheel torque i am guessing
      Blake Foster
      435-628-4300
      St. George Utah.
      TuoCo, CA
      Mr. Engineer.
      Can you post some pictures so those of us in a similar situation can see how your issue might compare to ours.
      Also can you please confirm that you had your rotor holes enlarged?
      Just looking for the truth between to passionate sides.
      Thanks.
      Steve
      Check it Out Here
      Judge Judy here,
      After looking at the photo evidence submitted by the defendant: It's pretty obvious that the rotors will cause the studs to back out if they are not properly re-sized to avoid the 1/2 inch stud's fillets.
      Case Closed.
      Bailiff, Please seize a set of those AFX spindles for.... a... research, yeah.... research.
