Thread: disc conversion problems
08-05-2010 #1
- May 2010
- 35
Hi All,
Got a 69 charger in the shop for a client/friend. Did a disc conversion on it from SSBC the car was originally a power drum. pedal feels is good but I cannot seem to get enough line pressure to stop the car. SSBC supplied a m/c that has a 1 and 1/32 bore. Here's what we have done thus far: Had a low vac condition and hooked up a electric vac pump direct to the booster with no change. Verified 20 inches of vac with gauge. Replaced booster with a dual 8 and 3/4 inch and no improvment. Installed a m/c from a 73 dart disc drum car with a bore size of 15/16ths. Slight improvement but not enough to drive the car safely. Bleed many times and no changes. Removed the stock dist. block and replaced with a direct tee circiut for the fronts and a straight coupler into the prop valve from the master and out to the rears.No Change. Linkage and pushrod clearance checks out. I have left a 1/16th to 1/32nd clearance. SSBC techs say to go back to the original booster and their master. I can't see this helping since it is a single booster and a larger bore combo. I am about to go to the parts store and buy a hydroboost system from an astro and get some lines made up and be done with it. Any ideas?
