      Dec 2008
      NY
      9'' center section
      Hey guys
      I have a question or 2. I am looking at the Moser website. There is a choice between nodular and stock ford 9’’ center section. What’s the difference other then the price?
      Also with a sbc and a 700r4 trans what would be a good gear for street and with the occasional road race.
      thank you
      John
      Hi John.
      I am no expert but the nodular case is just a stronger case. I ran regular cases in all my cars with no problems. If you plan to drag race with slicks and a hard hitting converter then it may be necessary to use the better case. If not the standard case should be fine.
      I run 3:90 rear gears. They work good for me on the street and track. I hit the rev limiter at 138 MPH at 6400 in 4th with a T56. 4th is 1 to 1 so it should be the same as drive with you trans.
      I have a set of used 31 spline 9 " axles if you are interested.
      Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      San Rafael
      I'm running 4.11's in my Camaro
      383 700R4
      Runs well on the freeway.... about 65mph @ 2500RPM
      Paul
      The stock Ford case should be fine for what you are doing. The nodular case is for high HP cars, around 600 HP. The Truetrac should work very well for road racing. A 3.50 or 3.70 would be all right with the overdrive. If you get on the highway a lot then I would use the 3.50.
