      Nov 2004
      Mini steering pumps, Hydraboost, and Unisteer Rack.
      I bought the Unisteer rack in the GP a little while back. I also got the modified aluminum mini power steering pump with integral resevior that will fit my Vintageair Front runner setup. Unisteer says their pumps are modified to provide reduced pressure and flow to give the correct feel for the rack.
      The problem is that I also want to run Hydraboost brakes because I plan to use an IR manfold for massive torque output. The hydraboost brake setups don't work well with reduced pressure. They recommend the stock saginaw type pumps with no modifications to avoid slow pedal return, and general overall problems with the hydraboost.
      BUT, even if I could get a regular saginaw pump to work with the frontrunner, I would have too much pressure/flow for the rack.
      So the solution seems to be, run an unmodified mini pump to the hydraboost, and then before the rack install a pressure reducing valve from heidts to taylor the flow/pressure for good road feel on the rack.
      I've been talking to the guys at Mavel (Unisteer) about what an unmodified mini pump can do....my question is, what pressures and flows are produced by the stock saginaw box? and can the aluminum mini pump make the same amount in an unmodified form?
      DSE installs a pressure reducing fitting in their pumps (same type pump as what Unisteer sells), and Unisteer modifies the pump in a different manner to reduce the pressure/flow. I need the right amount of flow and pressure for both systems, the hydaboost, and the rack.
      Opinions? Those with direct experience with both systems are required to respond
      TIA for your replies.
      ~~fred
