Results 1 to 13 of 13
Thread: pump gas Ls1 high compression
08-02-2010 #1
I'm going to be putting an Ls-1 together for my project car. I want to get the most compression out of it without having switch from pump gas. I want to get atleast 11.5:1 out of it, possibly more if i can. Stock cubic inch (346) ported heads setup for 2.02/1.60 valves and I'm planning on a cam in the area of 236/242 duration and lift in the area of .600 on a 112 lsa. This motor will have a carb on it. The ls-1 I put together for my brother is 11.1:1 with mildly ported factory heads, stock valve size and the ls-6 cam. That motor is pump gas with no issues. but it is still fuel injected with a knock sensor so if there was an issue, i guess the computer would just pull timing automatically. Let me know your thoughts.
