      Apr 2010
      is this gap in the perch a problem?
      just swapped in a ford 9" and now have a gap between the perch and spring. does this mean the rearend can move now? whats the best way to secure it if I need to?
      Aug 2003
      You went from a mono leaf perch on your orignal rear to a multi leaf perch on the new rear. You will need to fill that void with a block so you can sandwich down on that spring. Or ge a set of multi leaf springs which would be advisable anyway.
      Dec 2007
      Salem, OR
      x2 on what Frank said plus I would not move it at all under it's own power until you fix it or your tires could get very friendly with the wheelwells.
      Mike R
      '66 Olds Cutlass Convertible
      '15 Challenger SRT 392 (DD)
      '72 Pontiac LeMans (wife's toy)
      Apr 2010
      Frank -
      Thank you... I will be ordering some multi leafs and keep the car in garage a bit longer :-(
      Much appreciated advice- Thank you again.
      Scott
      Apr 2010
      Thanks to you also Mike-
      not wanting the tire to wheelwell relationship to friendly thats for sure.
      atleast I get to stare at it sitting there in the garage.. right?
      Scott
      Dec 2007
      Salem, OR
      No problem Scott. It gets tempting (especially if it's been apart for awhile) to talk yourself into just "a spin around the block" when something isn't right. It is a bad deal when the rearend decides to go for a walk. I've seen it mostly on lifted trucks. They shear the spring center pin and it usually tears the body and tires up pretty good if not just outright wreck them.
      Maybe it's time for ladder bars, you already have the floaters taken care of.
      Mike R
      Apr 2010
      Really - ladder bars also? I have traction bars and subframe connectors on it. get some ladders for it also?
