    Results 61 to 67 of 67
    1. #61
      Jul 2003
      Anaheim Hills, CA
      Video.. You need good speakers..
      1968 Track Rat Camaro:
    2. #62
      Den Helder, the Netherlands
      Country Flag: Netherlands
    3. #63
      Rustburg, Virginia
      I think I could almost see the top of the number two piston when the throttle blade opened WOT...LOL
      Sounds great!
    4. #64
      Mar 2010
      AZ
      What I wouldn't give to work and play in the same field. I know it's not my house or anything in it, or attached to me for that matter, hrm....
      Robert R.
      1988 S10 blazer 5.0L SBC 700R4 body off build.
      1991 S10 Blazer 4.3L too low daily.
      1975 Cutlass Salon currenlty 350/th350
      Stupidity should be painful.
    5. #65
      St.Petersburg, FL
      Quote Originally Posted by Steve1968LS2 View Post
      1. Factory MAF, O2, MAP, E40 and all of that.. just like a new car
      2. I have a Mike Norris ported 90mm.. I might have to look into the Nick Willams deal, hadn't heard about it.
      3. I don't think so.. these are Mast's Black Lable stuff which I thought was thier own.
      2nd gear is my friend
      I noticed that your dyno run was without the MAF, I picked up over 20 rwhp by using this 100mm maf over the factory one: http://www.powrmax.com/PowrMAF%20100.html
      Here is the NW's TB's:
      www.ls1tech.com/forums/new-products-showcase/1206144-sdpc-new-exclusive-distributor-nick-williams-dbw-throttle-bodies.html
      Once again great motor and congrats on the rock solid numbers!!!
      Matt
      '69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 T56 Magnum and once again tuned by Ed!
      '69 Camaro Convertible, all DSE Stuff, LME 430 LS7, tuned by Ed Hutchings and built by http://www.gforcedesignconcepts.com/
    6. #66
      Indianapolis, IN
      Nicely done, should be a beast. Did you get to use the V-Ring on the dyno run??
      When do I get my hands on her
      I got some more catch cans in, so let me know what you need.
      Talk to you soon.
      Mike Norris
      Mike Norris
    7. #67
      Dunwoody, GA
      Long time.. this was my "end game" deal.. besides, where else would I go?
      I might draw up a custom oil pan.. and if I ever have to tear it down I would add the oil squirters.. but other than that I consider this a keeper.
      I was thinking your last engine was the final one. I'm glad to see this one do so well though. Talk about making the last one killer.
      For a bigger TB, you can look here as well http://vmaxmotorsports.com/ Pete has had billet TBs out for longer than Nick and they work very well. Admittedly his website is not the greatest. Just pick up the phone and call him if you're interested. I've worked with Pete in the past and what I really like about Pete is that he won't sell you what you don't need or tell you bigger is better.
      Trey
      ~ Jon Hammond
