07-22-2010 #1
Problem installing QA1 shocks/spring
Ok, so i have a 69 Camaro that I am having modified into a PT car. Mechanic is having troubles installing the QA1 shock on the 69 camaro frame. He's having problem fitting the top of spring over the stock frame groove. it should fit nice an snug over the groove where the top of spring is suppose to sit. Instead, the top of spring cannot fit over the groove because the top of spring is too small in diameter. When installing these shocks/springs should the frame be cut and modified so the springs fit over the circular metal groove? or is there a larger diameter QA1 spring that fits nice and snug? any help would be much appreciated
