Results 1 to 20 of 21
Thread: C4 or C5 Conversion
05-11-2005 #1
New to Pro-Touring
- Aug 2004
- Carson, California
- 46
C4 or C5 Conversion
Is the C5 Brake System (Fronts) that much better than the C4 ?
If so, what are the advantages ? I have a C4 set-up and I would like to install them on my '69 Camaro. Does anyone make a caliper bracket to do this ? What MasterCylinder should I use ? Aftermarket ??
11-27-2005 #2Dave,
I'm new here as of tonight. I saw no one replied to your post. If you have not found your part yet, try speedtech performance they sell a bolt on bracket for about 125$ or you can build your own from a template available on David Pozzi's web site (just type his name in your browser)
I'm going with the pre fabbed with a C5 Conversion.
Hope it helps!
Lead
Ho Yeah! I know you can use either a disc or drum spindle with the speedtech bracket, but does anybody know if the bracket will work with an aftermarket 2" dropped spindle???LEADFOOT1
1969 Camaro Pro-Touring project SOLD!!!
NOW; as of 08-2006. Still a 1969 Camaro, BUT now a Convertible!, A 63 000 miles, 1 owner, 1 repaint in '78 that was stored inside from 1982 'till i got it car, and is now; Full custom tubbed to fit 19x8.5 and 20x13" Forgeline ZX3p wheels, w/345'-25-20's rear, C6-Z-06 brakes.
AirBAr suspended +++
1998 Dualie Crew Cab 3500/454 Fully Loaded.
11-27-2005 #3I believe the C5's are a stiffer design with bigger pistons. Do some searches, the answers are out their.
11-27-2005 #4
