      Near Dayton, OH
      Flush mounting glass
      Read through a couple of threads here on the board about flush mounting glass and the different approaches.
      I'm considering doing the front and rear windows on my '87 Cutlass mostly because I'd like to get rid of the trim around the window.
      I've heard that instead of buying a custom made piece of glass for each that you can instead weld up the gap between the window and window frame to achieve the same look. Has anyone done this and have pictures?
      How much room do you need to leave between the glass and body so that you can still have the glass installed properly? How do you go about setting this gap? In my case my window's are glued into place and the trim is there just to hide the gap. Would I need to have my windows glued back in temporarily while I weld things up? Or could I get away with just laying them in there?
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
