Results 1 to 16 of 16
Thread: Opinion Please
Opinion Please
I am currently running a Holley 4150 HP, 950 cfm, Square Bore carb.
I have a 502 w/ stock intake and full roller cam.
Do you think this is too much carb for this motor ?
Joe C
1969 Camaro
07-18-2010 #2
Banned
- Aug 2003
- Orlando, FL
- 8,745
Yes, I would run a 750 on that motor.
I would run a Holley 750 Ultra Avenger on it. I have sold and run these on 500HP to 600HP motors with great power and street manners.
They run $500
07-18-2010 #3Frank,
would you be able to put something together for me ? Correct jetting and sorts ?
It seems that me current holley has quit on me. My car current won't start unless I floor it. Once it's starts, it will only run at around 1800 RPMs, and runs very rough. It will not idle at all. Just started doing this last night, so I'm not sure what happened.
Any suggestions on what to check ? I tried tapping the carb a few times in case the float was stuck, but no luck.Joe C
1969 Camaro
07-18-2010 #4I also pulled all the plugs out, and they don't look too good.
Joe C
1969 Camaro
07-18-2010 #5
Banned
- Aug 2003
- Orlando, FL
- 8,745
Probably is a stuck float. You can pull the site screws out of the side of the bowls and see if fuel runs out.
07-18-2010 #6I've had pretty luck with Edelbrock carbs as well. 750 cfm and also the spring and metering valve kit to dial it in.
89 Supercharged Saleen 352 rwhp, 93 Mustang LX 347 stroker 420 rwhp daily driver, 78 Firebird, 69 Opel Kadett Rallye ex-SCCA track car..."everyone needs to own a 4-bbl 4 cylinder once"
07-18-2010 #7Frank, Are you around tomorrow ? Can I call you to discuss a new carb ? I'd like to get something from you ?
Joe C
1969 Camaro
07-19-2010 #8good carb
that carb should be fine if not great w/ that 502.
pull the bowls and metering blocks off & spray em out w/ carb cleaner. blast the needle and seats. put in a 5.5 powervalve & drop 1 jet size in the primary.
same w/ the back but leave the jets alone. 6 to 6.5 fuel psi . set the floats properly. make sure there is no slop in the squirter diaphram linkage.
b bump up the timing a hair in that 502. set the idle with your idle mixture screws and the primary idle screw.
you should be rockin.
idle at 850 - 950462 Doug Nash 5 Speed Centerforce Clutch Quicktime Bellhousing Edelbrock Heads Solid Roller Holley HP Victor Intake Pump Gas 66 12 Bolt Poly Bushings Hotchkis Springs Metco Control Arms Big bar front Stock rear bar INTRO 20's & 19"s
07-20-2010 #9
