    Results 1 to 1 of 1
      T-56 Tailshaft bushing
      I changed the tail shaft bushing in the T-56 in my 68 today. It was actually not a bad project. It took a little longer than I thought it would, but the result was worth it.
      I highly suggest to anyone that's going to attempt this that you freeze the new bushing. Put it in a baggie and stick it in the freezer the night before. I also suggest that you use something that supports the inside of the bushing while you're tapping it in. I used a large socket with a stepped outer diameter that worked like a charm.
      Also, be aware that the reverse shift rod drops down if you do this with the transmission in the car. I used a small phillips screwdriver to hold the rod up while reinstalling the tail shaft housing. It slipped right back in to place.
      In my case the swap greatly improved the driveline vibration my car has been plagued with for awhile. It still has a slight deceleration vibration that I think is caused by a worn yoke. The yoke is only 42 years old so it's probably due to be replaced.
      GeoffP
      68 Camaro - LS1/T-56
