      Jun 2009
      Central FL
      LS1 front caliper wheel clearance
      Ok, I was going with IROC wheels, but I don't think they'll clear with this bracket:
      http://www.kore3.com/proddetail.php?prod=10083-01
      But I'm not using a C5 caliper, so I assume this will work with an LS1 caliper? But I'll still get the larger rotor from the C5? Am I correct so far?
      So I decided I run SS 10 spoke wheels...
      For reference...
      Crude Photoshop, but it works.
      These wheels are 17x9 all around and came stock on 2002 SS's.
      I'm fairly sure they'll clear for this setup, but it couldn't hurt to ask
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      zachary louisiana
      yes the will clear the 17" for sure. im not running the kore3 brackets but some i made they dont look as big as those and im only running 16" rims and have no clearance problems with the lsi calipers
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      Pensacola, FL
      I have C5's on the front of mine & I had to grind off the fins from the calipers to clear my 17" Bonspeeds. I wasnt expecting that, but the LS1's seem to have more clearance.
