    Page 2 of 2 FirstFirst 1 2
    Results 21 to 36 of 36
    Thread: D52s and pads
      Jun 2006
      Katy,TX
      Bob I have one in my storage space I'll drag out this weekend. Want to weigh it also to compare weight.
      Also got a rear caliper with the piston out to measure.
      Melbourne, FL
      Quote Originally Posted by a67 View Post
      As I posted, with calipers it is piston diameter, not bore diameter that matters. Yes, with a 2-15/16" bore it will have 6.77 sq/in of area.
      But the piston is smaller. Lets use a 1/16" smaller diameter then the bore. Which gives .031" clearance between the bore and piston.
      Now the piston area, which is what counts, is 6.16 sq/in of area.
      Which is smaller then the Wilwood's.
      So, where does this lead? Anyone have a stock GM D52 piston around that they could accurately measure? This is the only way to be sure of the true piston area.
      Bob.
      I have several in my garage that are easy to access. What exactly do you guys want measured?? Some are even still disassembled. So shouldn't be to hard to get the measurments you want.
      And just to be clear. We are talking about the large stock single piston front calipers. Right ???
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Little Rock, Arkansas
      If Skip doesn't. I might have one in the attic but I really don't want to go up there on these 100 degree days.
      Jun 2006
      Katy,TX
      Amen!
      I'm assembling a motor in the garage and keep dripping sweat in it making the deck get rust spots!
      Correct. The OD measurement of the piston is what's needed if I'm understanding all this correctly.
      Skip, suspension work in my garage so it's a little less critical. I'm just sweating on the greasy parts coming off right now.
      Melbourne, FL
      Quote Originally Posted by critter View Post
      OK I took a measurement of one of my pistons then double checked it by going online to Rock Auto. So, I'll use Rock Auto's measurements which is 2.934" diameter. So basic calculations yields 6.761 sq/in.
      Hope this helps.
      Quote Originally Posted by 67 455 Bird ragtop View Post
      Hope this helps.
      Can you post the piston diameter? Rock Auto lists the bore diameter. Which we don't care about.
      To measure the piston OD will need to use a set of dial calipers (no pun intended). Or a fancy digital set. A steel rule most likely won't cut the mustard.
      Thanks.
      Bob
      Melbourne, FL
      Thanks.
      Bob
      Actually they list this as the piston diameter not bore diameter.
      RAYBESTOS Part # DPS85010 Professional Grade; 1.95" Overall Length / 2.934" Piston Diameter / Steel
      Front; Steel
      Front; Steel
      And these are listed under the '70 Camaro and the same size as bore diameter:
      RAYBESTOS Part # FRC4059 More Information About this Part Professional Grade; Friction Ready - Pads Not Included, Remanufactured; Bore Size=2.94"
      Which is rounded up from 2.9375. Which when combined with the other value, a piston to bore clearance of 0.001,75". Which is real tight, too tight.
      This is why it is important to get measurements from actual parts.
      Bob
      Melbourne, FL
      I'll look and see if I have a front caliper I can take apart. All I could find in the garage were rears which are different piston sizes. But the bore is 2 15/16 which is 2.9375. Subtract the piston size of 2.934 and you get a gap of .0035. Not all that tight if you've ever rebuilt these things. They are a snug fit.
      Ok I went out and pulled down one of my front calipers and popped the piston. I had been contemplating stripping and repainting them so this gives me an excuse. I used a digital caliper on the piston and it indeed measured 2.934". And these are stock original pistons. They just don't have much use on them since I haven't driven my car since 1990 and I did the switch over in 1982 using a junked 1970 Chevelle disk brake setup.
      Thank you for measuring the pistons. As for the "get a gap of .0035", you need to divide it by 2 for the clearance. As there is clearance on each side of the piston (hopefully equal).
      Using this information lets then go back and compare the Wilwood D52's to the stock D52's:
      Wilwood: dual 2" pistons, 6.28 SqIn
      GM D52: single 2.934", 6.76 SqIn
      Now, what kind of difference is this: 6.28 / 6.76 = 7.1%
      This is a 7.1% difference in brake pedal pressure for the same clamping force. Which is 107 pounds on the stop pedal vs. 100 pounds on the stop pedal.
      Is that enough to worry about. And, since you are serious about braking, do not the higher friction pads make up for this. And, does the better braking feel mean anything.
      I know the answers to this for one of my cars. Because in the front brake swap I gave up more then that in clamping force. And have absolutely no qualms about it. It was/is a very good trade off.
      Bob
      Jun 2006
      Katy,TX
      You saved me a trip to the storage place-well I got to drop a check by today anyway. At least not digging in there with 95 and 100% humidity-rained last night supposed to again today.
      I'll measure one of my WS6 rear caliper pistons. Wilwood is supposed to be coming out with a dual piston metric caliper that would fit the rears, just no E brake.
      Here is a picture of the caliper the Hawk pads on a GM 1LE rotor. Slides right on.
      Jun 2006
      Katy,TX
      Cast Iron on a dgitial is 8lbs 15 oz(8.94)
      Also the rear WS6 caliper piston is 2.492" where it rides on the O ring. Smaller on the outer portion that has the pad clip groove. Not sure how that compares to the Caddy rera calieprs or the Explorer calipers with the integral E brake.
      So it appears that our original assessment on how the brakes will react to the change in caliper is the same. While there will be a slight increase in brake performance with the swap one shouldn't expect earth shattering differences in the feel or reaction of the braking system.
      A little under 3.5 pounds per side in weight savings then. That's unsprung weight as well. That alone is a big help.
