    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 43 of 43
    1. #41
      Jun 2005
      Greenwood, SC
      Quote Originally Posted by CCC View Post
      What is the advantage of bags over adjustible coil overs? Do they work as well on the track or just make a nicer ride on the street?
      Modern bags are very similar to coilovers and work very well on the track--better or worse than actual coilovers is a tough argument, as you'd realistically have to have two identical cars with the same setup (other than the springs) to make an accurate judgement-- but, at the end of the day, to some extent a progressive rate spring is a progressive rate spring, be it made of air or steel. Both springs offer a level of adjustability that is tough to achieve with separate spring-shock units, the air is just a little more on the fly as you can just punch a button or two and retune your springs. When I took the car autocrossing, we were able to readjust shock compression, rebound, and spring rate between every run- it's that quick of a process. Coilovers would have been slower, and might have required waiting until you had finished all your runs to retune spring rate. The fastest car of the day was on bags, and the second fastest was on coils. So, is either setup really "the hot ticket"? No, IMO. If you're more "set and forget", coils may be for you. If you're the type that fiddles a lot with your setup-or the type that needs to be ready to roll rapidly in a variety of situations- air may be a wiser choice. Me, I keep my car as low as I can around town, but in order to get my car home I have to clear several 12"+ speed bumps. With any other setup, I'd be playing taps for my headers in less than a week- this way, I can just punch a button and it's "go go gadget 4 by 4" mode.
    2. #42
      Birmingham, AL
      The ridetech guys have done a pretty good job of taking their cars out to the Autocross track and proving that it is a worthy suspension option for the Autocross/Road Course. There are plenty of videos out there and on their website. It will come down to whether you want the adjustability and the extra weight of the compressors/tank, etc. I am sure this is minimal. I am on the fence in some regards because I do have to deal with some pretty interesting terrain and steep driveways.
      Stephen
    3. #43
      Jun 2005
      Greenwood, SC
      In popular hotrodding's testing, air ride's complete kit actually saved a significant amount of weight over stock suspension. Clearly, throwing out the compressor and tank and using coils in the same setup would most likely save even more weight, but I just wanted to put things into perspective against an easy benchmark.
