      Decided on SS Brake lines, need some tips and sizes.
      I've lost my info off my old computer about the AN and standard fittings I need.
      I want to switch to SS lines with a single flare AN fitting where I can. However, I'm not quite sure how to go about it.
      I bought a manual master cylinder from Touring Specialties, which I believe is from a 1970 Corvette with a 1" bore. I also got the adjustable push rod and need to know which hole in the pedal it mounts to and the approximate length.
      I'm running stock rear drums for now, probably be disks before the car is on the road, and a SSBC disc conversion for 15" wheels up front.
      I need to know what size AN and other fittings I need for it and for the SSBC prop block, if it's know.
      I plan to buy the Ridgid flaring tool, but I could use some advice on it's use.
      Thanks!
      Thomas
      Spare Change: 68 Camaro, 300hp/350ci, 700R4
