Results 1 to 15 of 15
- Jan 2009
- Rochester, NH
- 54
1st gen Camaro front shock Air Ride issue
I thought I'ld post this recommendation for people with first gen Camaro's/Nova's with an air ride system. Check you front shock mounts to ensure the welds aren't breaking. I don't remember if the installation instructions for the air ride recommended reinforcing the mounts or not, but I've had the welds for the passenger side mount break twice and the drivers side broke this past weekend. This is the mount on the subframe itself. i determined this mount wasn't designed to support the full weight of the car over time and does break. I re-welded them and added some gussets that will hopefully solve the problem. This may be applicable to other car as well that air ride uses the shock mount to support the weight of the car vice the spring perches as was originally designed.
Derrick
1969 Camaro, LS3, 4L80E, Air Ride Street Challenge, Baer Extreme Pro 6S disc brakes, 19" and 20" Rushforth wheels, Dana 60, a lot of custom pieces and still working on it.
Pictures located here : http://s330.photobucket.com/albums/l...i/69%20Camaro/
2008 Charger SRT-8 SuperBee and 2008 Dodge RAM 2500, 6.7 Cummins and 2006 Cadillac SRX
