Thread: Fuel leak
07-08-2010 #1
- Nov 2008
- 81
Fuel leak
Went to prime the fuel system today and check for leaks... sure enough I have a pretty good stream from one of the fittings. Its a ricks tank, S&P LS camaro fuel line kit, and some braided lines I made up to connect the tank to the filter.
The leak is between the fitting on the supply line of the tank and the -6 male to male connector. I losened it up and retightened with no luck. tomorrow I plan on swapping the -6 connector around. Is there anything else I should try or look at? I did turn the key the first couple times with the supply and return lines swapped, don't know if that would have any effect.
Pete
