      McKinney, TX
      Over sensitive steering
      OK, 66 Mustang with rack & pinion, 620lb springs, A-arm drop, ST sway bars, new bushings, shows no abnormal tire wear. The steering is VERY sensitive and almost wonders while driving. It tracks straight and NO SHOP in town will align it for me so I honestly don't know where it's at. Is this a caster issue?
      89 Mustang "Box Wine"
      Mountain Springs, Texas
      Is that a power rack? If so, maybe the pressure is too high. Had a similar problem until Matt from AME set me up with a lower pressure pump from KRE.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      McKinney, TX
      Yes, it is power. I am running a Randall's Rack power set-up.
      Aug 2005
      Hamilton, NJ
      What are the alignment settings? Toe out can make a car darty.
      Scott from NJ.
      Vent Windows Forever! ...
      Rockford Illinois
      Don't know what the problem is but the best thing I ever did for alignments was to learn how to do my own with the string method. You can google it and probably find the info you need to make the setup yourself. I made mine from conduit and some brackets. $20 is all it took along with a friend who has a camber caster gauge.
      It sounds like an alignment problem but it could be pressure too.
      Goodluck
      Rustburg, Virginia
      If your're interested:
      For home alignments with simple hand tools...Todd did a pretty good job writing this up and posted it on his website. Check it out.
      http://www.nastyz28.com/~Todd80Z28/p.../alignment.htm
