    Results 1 to 19 of 19
      Paint or Powder coat for core support? Need a common black paint code.
      I'm thinking about powder coating my core support and the fender support bars rather than paint as it seems to hold up better for reassembly and changes down the road. My cross member has held up great during the install, much better than some painted items, so I was interested in seeing what everyone's ideas are.
      Also, I need a good, common black for the engine bay. Somewhat matte to semi gloss. What's a real common code? Good durable black, Standox is too soft. Any suggestions? I think I'd prefer single stage as it would work better for my setup and any retouches, but I'm not sure.
      Thanks!
      Thomas
      Spare Change: 68 Camaro, 300hp/350ci, 700R4
      Apr 2004
      OKC, OK
      We use Sherman Williams Polane Carbide black. it is roughly the sheen of EDP, semi gloss, cleans easy, durable as hell. Once fully cured, almost impossible to chip it.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Aug 2008
      Pgh, PA
      I would not hesitate to powdercoat a core support. If it's going to be semi-gloss to begin with, just get your core as smooth as possible and it'll hold up far better than any paint.
      Feb 2003
      St. Louis, Missouri
      Eastwood Chassis black.
      Rick Butterfield
      May 2008
      South Jersey
      Quote Originally Posted by Happyfunballs View Post
      x2, or Eastwoods underhood black
      Nick
      '67 Chevelle 350/th350..... soon to be all aluminum 5.3
      '73 Chevelle 4.8/th350
      Thanks all!
      I thought about the Eastwood Chassis black, as it's held up on my sub frame pretty well.
      Thomas
      I like the idea of the Polane. I imagine no top coat and seems fairly easy to spray.
      Any photos of the end product? Thanks!
      Thomas
      Apr 2004
      OKC, OK
      Quote Originally Posted by Rileys68Camaro View Post
      no topcoat and i over reduce to get it to flow out.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Mine is powder coated
      Eastwood has powder to match their chassis black. You'll be able to match with the paint.
      This is rite from their tech dept.
      DETAIL GRAY would be the Stamped Steel #10099
      SPRAY GRAY would be Cast Iron #10095
      UNDERHOOD BLACK would be Satin Black #10103
      Hope this helps.
      Sep 2009
      Port Richey Fl
      SPI black epoxy primer after it has cured 7 days will give you a semi gloss very strong finish.
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
      Aug 2008
      Pgh, PA
      Not a big fan of Eastwood Chassis Black. I've found it to not hold up as well as POR-15.
      There is no paint that holds up as well as good powder coating.
      It all depends on what you're trying to do.
      Awesome, that's exactly the look I'm going for!
      Any other tips and tricks? I need to bond in a DSE Fill plate, and wet sand the fenders and firewall that have been painted base/clear all ready, just changing color. Thinking 800-1000 grit wet?
      As to POR-15, I've used it, but it's some crazy stuff and I'd not want to risk a spray gun for it. Looks great on my master cylinder and such.
      Thomas
      May 2009
      id use 600 wet and grey scotchbrite
      Ramona, Ca. San Diego area
      lots of good idea's here. I used hot rod black on the whole engine compartment. goes on shiny and flattens out when it drys. Single stage paint, easy to spray too.
      67 Camaro convertible (Jinx)
      I used to think powdercoating was a solution looking for problems, but found it to be more trouble than it's worth. It tends to lift up at fastener locations, and there really isn't a clean way to work with it if you decide you want to make changes later. Also, it's very edge thickness dependent with respect to corrosion. If you have sharp edges (sheet metal), it will tend to corrode more quickly if you don't lay down sufficient powder.
      My POR15 experiences have always started off looking good and resulted with the product lifting and peeling later -- on both lightly and heavily rusted applications. It may be that I did something wrong.
      Aug 2008
      Pgh, PA
      Quote Originally Posted by JohnUlaszek View Post
      Are you doing the powdercoating yourself? I've never had a single instance of powdercoat lifting at any location, including on sheet metal and on more substantial areas like frames. I've also never had it corrode in the past 10 years. I would guess that the process itself could have a large impact. Biggest PITA I've had with powder is making sure it's not too thick and clearancing areas that require tight fitment.
      Yes, lots of good ideas. I'll probably be surprised at the price of the Polane, but what the heck, seems a great product.
      I've been hearing mixed results on the Chassis Black.
      Now I've got to buy a spray gun.
      Thomas
      San Rafael
      I really like GM Black Reconditioning Paint
      http://cgi.ebay.com/ebaymotors/GM-BL...item3ef6640df6
      Paul
      I think I'm going with the Dimension line as the Polane is tough to get and get info on.
      I may try a Factory Pack, as I just need a black that's easily duplicated. I'll have the add a flatner as per Franks advice.
      Thomas
